Custom engraved PTE GN1 valve covers $100 shipped
Don,
Will they not work with stock iron heads? let me know and put me first in line?
Thanks,
John
Yes they will fit on iron heads. The GN1 style valve covers are just taller to clear the taller rocker arm assemblies. I will warn you the bottom left bolt is a PITA to get to on the passenger side with the stock ac/heater box. You have to use a swivel to get in that tight space. Using your torque strap (if you have one) to pull the motor more towards the driver side helps. Other than that you will have no problems! Let me know ASAP.
