My old block needs a line bore done on the cam journals. I already had to put a #1 bearing in the #2 journal (b/c the #1 bearing is .010 larger O.D.) to fix where the #2 bearing spun.
Who makes oversized cam bearings? Would my block be a candidate to go roller on the cam bearings? (assuming you have to bore the cam journal holes anyway to accomidate the roller bearings)
