I have looked at some pics from the F1 stuff and noticed the tuned length. I didn't know enough details of their rules to know why they may have went to the tuned length exhaust. Rules like if they were turbo limited. I had heard at one time they were boost limited but never researched it. I don't have room for tuned length anyway. I figured they were like NASCAR. They will work for 2 years and spend $200,000 to find 4 horsepower. Mentally I put this technology in the same group. They may have found power but how much. 4hp or 40hp?? I thought you may have seen some testing to know what kind of gains. Thanks for the explanation
The only testing that I have experience with is on a desktop dyno. Many, many hours on a desktop dyno. Also, a little coaching from a few very good engine tuners. In fact, one of these fellows turned me onto the engine sim I use to this day. An updated version, of course. It's very enlightening what you can learn by tweaking this and that on a sim.
When I was putting together my configuration, the foundation of the combination was going to be the heads. M&As. At the time I was putting together my combination, M&As were the only aftermarket heads available. I had them max ported and flowed, sticking with the original size valves. There is an intake port gas flow velocity target that is optimum for an engine and the sim let me know that to optimize this particular head I would need to destroke the engine. The shorter stroke slows down the velocity through the intake port for a given rpm. Hence, increasing the rpm capability of the engine before reaching the flow limit of the intake port. I picked a stroke of 3.06". The destroked crank also gave me a stronger crank pin arrangement. There is more meat at the joining of the split pin with the shorter stroke. A more durable arrangement. An added benefit.
Next came the camshaft specs. With the loss of displacement with the shorter stroke, I knew I would have to make up for it with rpm.
If you take away from any one of the 4 variables that ultimately produce horsepower in an engine, you can make up for the loss by increasing any one of the other variables. The 4 variables are P.L.A.N. Some may have seen this in a popular turbocharging book.
P = cylinder pressure
L = length of stroke (crankshaft stroke)
A = cylinder piston area (bore diameter)
N = rotations per minute (rpm)
The head and crank combination was now setup for high rpm operation. The next specification to look at was camshaft.
The intake duration is the primary specification that sets where the useful powerband of the engine will be. In what rpm range.
If you want rpm, you must increase durations. There is no other way around that. The sim let me know that my heads, with the given stroke, would be done at 7800 rpm. I next picked an intake duration figure that would give me usefull power to 7800 rpm. The rest of the cam specs were picked to support the intake duration spec and the shortcomings of the head. A little more duration for the exhaust side to balance out the flows.
Whenever you increase durations, you will increase overlap of the intake and exhaust events. If you want rpm, you are going to have overlap no matter how much you play with lobe separation angles. Seeing that I was going to have to deal with a lot of overlap, I decided to pick a lobe separation angle that would be the most efficient for the engine. Not just one that gave me the least overlap.
Will be back.
