Dec 25, 2008 #1 O oldguy Member Joined Oct 27, 2007 Messages 64 with .082 cyl. wall thickness on a stage 1 block, can 25# plus boost be run safely? what is the no go cyl. wall thickness?
Dec 25, 2008 #2 T turbofabricator Well-Known Member Joined Mar 7, 2004 Messages 4,261 That really depends on WHERE the .082" thickness is. Top, bottom, or thrust side?
Dec 25, 2008 #4 T TurboCrazy Turbo on the brain! Joined May 26, 2001 Messages 324 Throw a little Hard Blok in it to stiffen up the cylinder walls and you should be fine. Alot of the stage I blocks had this annoying little problem.
