Junior Samples
Walk Away
- Aug 3, 2007
As I am still awaiting the arrival of my scanner I decided to check my cylinders and my readings are all 130#s
Now I read on GN.org they should be around 150?
The Block is 30 over and with only 2000 miles on motor, if readings are down that much although consitant....I may have to pull the damn motor this winter and do it right because IM really starting to question the local Mr smartypants socalled GN guru who built the motor.
I guess it started with finding the Y restrictor on wrong.
Anyway what should my readings be per cylinder?
Mike
Mike
