aaron87turbogn
- Aug 1, 2014
Yesterday I did a leak down test and seems as if my calves are good and my piston and rings are good but when I put pressure in cylinder in the middle on driver side air was pushing out the 2nd push rod hole in in the 1st cylinder but cylinder 1 had 150 psi compression and cylinder have problems with is 30 psi has brand new head gasket
