CZ 2004R trans with billet drum and input
brian
Senior Member
CZ 2004R trans, fresh & ready to go.
This is a solid bottom 10 sec capable street/strip trans.
Billet drum and input shaft, fully rollerized gear train, front pump and output shaft (thrust washer replaced), Sonnax servo, and manual trans brake (stage right type) This is a lock up trans. WOT upshifts will be between 5600-5700 depending on the combo used.
This unit also has 550 and 400 boost valves, rev kit, Alto wide red band, billet anchor pin, and extra clutches throughout.
shifts are mild/medium at part throttle, firm at WOT. (not harsh)
$2500 outright shipped to you (cont U.S.). Look around and compare prices, this is a great deal with a real CZ core included. Or $2750 with a deep sheet metal pan installed.
1 year warranty.
Feedback can be viewed in the feedback area. Search under, brian or Brian Hofer.
Thank you very much...
Brian hipsibri@cs.com
This trans features:
Billet forward drum
Billet input shaft
Billet anchor pin
Transbrake
Sonnax billet servo
Alto wide band
7 directs
5 forwards > clutch packs
3 clutch OD
Rollerized pump, output shaft, low roller, drum, center support
upgraded TCC switch
new pressure switches
higher pressure spring
rev kit
550 and 400 boosters
hardened stator support
resurfaced pump
all new bushings and bearings
AND MORE
Lets Talk
Brian,
Give me a call when you have a free moment, lets talk.
Dennis 907-590-0592 -1hr PST
Do you accept cores to drop down the price? I have a complete stock 200 trans that needs rebuilding.
Don,
Yes, I typically give $300 in trade. I would also be willing to drive and meet you instead of shipping , and will cut off $150.
Brian
Tranny Man
Brian,
Give me a call or PM me ASAP!!!!!!!!!!
Don,
If you need me to get him the cores let me know.
I should be meeting up with Brian very soon.
Jason
AffordableGN
shipping to ak
Hey Brian,
I found out that North West airlines or Delta fly freight direct into Anchorage from Detroit.
This might be the best way to get the tranny here.
Den
