cz trans question
Sal Lubrano
I have a cz 200-4r out of a monte SS which skips second gear. Also the middle ear is broken off so it only bolts up with 5 bolts. I want to dismantle it and only keep what is of value. Need to make some room. Could someone please tell me what I should keep?
Sal
Keep the valvebody and govenor at least. Keep any other internal parts that you think you might need if your into rebuilding these transmissions. The direct clutch drum comes to mind.
Sal keep everything and just junk the case if your planning on building one in the future.also if its a universal case ,depending on theintended useage the broken hole may not be required with the use of a buick engine or vise versa so it may still be a usable case
