Dash Issue
jshilli1
I was out driving today and the alternator stopped charging.
86 T-Type with Digital Dash.
Now, I did a search and located the "bat light" issue and how to bypass it with a resistor and all of that. Temp fix was to run clip a test light in line to positive. The funny thing is, the "bat" light never came on before and the alternator charged fine. After checking into it more, none of the idiot lights on my dash work except the check engine light (seperate and not on a PCB in the dash), and the brake/powermaster trouble light. I noticed that some time ago, the boost lights and turn signal indicators stopped working.
Is there a likely loose connector that could cause all of this, or is it likely an issue with the PCB in the dash? Fuse maybe?
Most likely it's a bad connection between the dash cradle black connector and the dash cluster. Sometimes, the cradle connector slips out of the locks and moves forward, causing the bow terminals to miss their target.
It's possible the alternator would charge with a dead bulb IF you have the white plastic ALT resistor lamp socket in place. Many of the digital dash cars had this part, but not all of them.
I have seen quite a few flex board failures on both the digital cars and the analog cars. The board is no longer available, and I'm working on a replacement board now. When the flex board fails, you will find problems with the telltale lights working, and also the illumination lamps failing or dimming.
