ChrisCairns
Senior Member
- May 24, 2001
Thanks for the tidbit of advice on my missing problems with the MSD box. If you remember I had a high rpm miss with the MSD box and the miss would go away when I disconnected the box.
I ran a 2 gauge wire right from the bat to the engine block...in fact right to the manifold bolt that the MSD ground comes off...and at last nights races the miss wasn't there. So it turns out it was a ground problem.
On another note....the damn $600 Weldon 2025 broke last night. The motor still runs but the pump doesn't move anything so I assume the shaft or coupling between the motor and the pump broke.
Bummer....I think I'll be finding out how Weldon's customer service is on Tuesday.
Chris
Chris
