What are some of the possible causes of a dead cylinder? Bent valve, cracked valve, etc. I did a compression check on a motor in an '87 T on Sunday, and the #4 cylinder reads only 30~ PSI!! The rest were at 130#.
I'd also like to add, that this car has been sitting for the past 6 yrs or so.
This T has 133K miles on it.
Am I correct in assuming that a valve is the culprit?
TIA!
TIA!
