Dead cylinder!!!?
Geoff87
Administrator
Staff member
What are some of the possible causes of a dead cylinder? Bent valve, cracked valve, etc. I did a compression check on a motor in an '87 T on Sunday, and the #4 cylinder reads only 30~ PSI!! The rest were at 130#.
I'd also like to add, that this car has been sitting for the past 6 yrs or so. :eek: This T has 133K miles on it.
Am I correct in assuming that a valve is the culprit? :confused:
TIA! :)
Wouldn't there be oil in the coolant, or vice-versa? :confused:
Oil is clean, as is the coolant. :(
not if it blew between cylinders.
Pull the valve cover and see if the valve is going up and down.
Just wondering.....
I didn't have time to check if the valves are moving, but...
If the head gasket blew between cylinders, wouldn't there be two dead cylinders, instead of just one?? :confused:
One of the more common head gasket "blow" methods is to go into the intake valley, or out the bottom of the cylinder toward the header. That will yield a dead cylinder and probably no oil in coolant, and no coolant in oil (unless it was bad enough to hit a steam hole).
If you had a valve hanging open I would think you wouldn't be able to see ANY compression. Same with a hole in the piston, NO compression.
But a blown headgasket will show some pressure if it's not too bad.
