Dead WI Pump
bruce
Rest In Peace
Would using a Walbro 340 be overkill for a WI system?.
I just happen to have a low mileage one, sitting on the shelf. Or what is a good in bottle pump to use?.
TIA
Guess you could. Tho I would runs tons of lube with it tho. And the pressure being what it is, may need more than one nozzle to make any noticeable effect. So it has two strikes, low pressure, and its not really compatible.. but will work.
Use denatured which is not as corrossive as methanol. And keep water away.
HTH
