Hey guys
I have an 86 and 87 Turbo regal.The 86 has working powermaster but slow leak around pump.The 87 is giving me fits and pump runs constantly,replaced switch, bled etc and I have decided that it needs to be sent off for repair and hoping to get unit repaired properly thru Cardone and my local parts guy.He will send off.
I am willing to convert the 86 over to Hydraboost since it is not as an original car.
My question is has it worked out for everyone to go the route of using the 84/85 TR hydraboost setup and hoses and the 81 caddi eldo brake master with plastic reservoir.Does it work okay to use the 86 pump I have and split into return line or get the 84/85 pump with separate pump return lines.I have found everything at local parts suppliers but have not purchased.
