definately something for everybody!!!
BLACK MAGIC RACING
formerly turbo_canuck
86/87 parts:
-Stock heater core- $60
-Stock crossover pipe(2) -$ 35 each
-stock intercooler - $80
-stocl i/c shroud+scoop- $30
-turbo heat shield - $30
-3.42 richmond gears - $90
-stock intercooler shroud - $20
-stock exhaust elbows (2) - $10 each
-stock inlet bells (2) - $5 each
-stock up pipe - $20
-stock wastegate actuator $15
-turbo brackets (2) $15 each
-clear parking lenses - $15
-stock posi rear - $800
-stock turbo (core) - $90
-stock front sway bar - $40
-4 stock t-type wheels w/ caps - $275
-front GN bumper - $100
-pair gn lower door panels- $60
-complete engine harness - $250
-4 GN wheels w/ new caps- $300
-2 85 gn wheels with broken center rings (good for slicks) - $100
-stock gn valve covers - $60
-stock downpipe (2) $20 each
-stock fuel pressure regulators (3) $20 each
-2 stock ECM- $75 each
-a/c lines - $50
-2 stock turbo cranks - $300 each
-Blower motor- $50
-Flexplates (2) - $35 ea.
-Throttle body and plenum, no arm, spring or iac- $ 125
-Cruise control unit- $ 40
-EGR valve and solenoid- $ 50
-Stock shifter- $ 30
-Right side air dam- $ 25
-Stock intake-shaved .030 - $80
-water pump pulley (2)- $30 each
-Stock fuel sending unit- $30
-Stock 87 Grill- $90
PERFORMANCE PARTS:
-ATR stainless headers for stock style heads- $700
-Champion GN1 Aluminum heads, w/gn1 valve covers, scorpion roller rockers,head stud kit-$1400
-Ported intake W/ 70mm Precision plenum, RJC power plate, 70mm Accufab throttle body, Accufab regulator on modified fuel rail, EGR block off plate, .- $550
-Pair of 1026 fel-pro head gaskets- $80
-March underdrive pulley kit w/intercooler fan- $120
-Chrome moly stock length pushrods- $50
-B+M line lock- new- $60
-New heated 02 sensor kit- $80
-204/214 speed pro hyd. cam - $75
-.030 speed pro forged pistons - $200
-MAF translator plus w/ custom engraved cover- $195
-ls1 maf sensor - $85
-ECM modded for low impedance injectors- $145
-Extender Xtreme chip for 95's- $90
-95 lb Delphi injectors- $300
-4.10 richmond gears - $125
-B+M torquemaster torque- 2800-3200 stall, th350,th400- $200
-2" to 3" reducer hose-blue- $20
-2.5" to 3" reducer hose-blue- $20
-3" by 3" long intercooler hose- $10
-2.5" by 3" long IC hose- lt. blue-$10
-High pressure adjustable wastegate actuator te series - $60
-High pressure wastegate actuator-ta series- $60
-Various t-bolt clamps- $10 each
-RJC power steering pump pulley- $50 new! sale pending
-RJC water pump pulley- $60 sale pending
-RJC crank pulley- $120 sale pending
-RJC Idler pulley- $50 sale pending
-Lokar trans mount dipstick + tube- $50
-alternator fan- $10
-BRF core transmission- $250
-Moroso trick rear springs w/ airbags- $145
-Pair of mint redone GTA rears- $ 225
-Weld 15x8 prostars, 4.5"backspace, drilled for screws- $200
-Pair of 8.5" vectors, centers painted black, holes drilled for screws- $175
-Pair of 8.5" vectors, good shape, $250
-4 polished center lines- 2 15x7,3.5" bs, radial tires, 2 15x8.5, 4.5" bs, 26x10 slicks.- $800
-Weber Billett roller cam, 218-212, 511,503 lift. 113 lsa.- $275
-Weld 10x15, 5.5 BS w/ 28x 10.5 mt et drags, - $500
-Auto meter 5" tach, w/ shift light, recall - $90
-New Heavy duty GN 2004r driveshaft, w/yoke, new spicer joints.- $350
-Terry houston 3.5" stainless downpipe with dump pipe, was dented in at one point to clear frame... $400
84/85 PARTS:
-complete intake - $90
-turbo/ throttle body assy. (core) - $80
-engine accessory bracket - $25
-braided down pipe - $20
INTERIOR:
-Grey steering wheel- $45 (rough shape)
-Green Steering wheel- $80
-grey dash pad - $80
-rear quarter window trim - $15 pr.
-3rd brake light - $5 each
-t-top wide front trim - $10
CAR AUDIO:
-Alpine CDM-7861 flip face cd player- $150
-Alpine CDA7863 flip face cd player- $ 190
-MTX thunder4122 2 channel amp- $ 100
-Memphis mono amp 16pr1kd- $ 250
FRESH LONGBLOCK ---10-15 RUNS:
10/10 stock turbo crank
billet center mains
RJC girdle
stock checked + magged turbo rods w/ ARP bolts
.030 forged speed pro pistons, plasma moly rings
comp cams 212-212 hydraulic roller cam + lifters, roller cam button
rollmaster timing set
comp hi-tec pushrods
hi-volume front cover
RJC head gasket kit
Fully race ported iron heads
manley severe duty stainless valves 1.77/1.50
t+d shaft mount roller rockers
comp "beehive" springs, retainers, and locks
cost me over $5000 u.s to build, sell for $4000,(or $4500 with complete intake above) only 10-15 runs on it!!! Ran 10.53 on soft 1.70 60' foot times @ 136mph
Prices do not include shipping! :biggrin:
Did you ever get any pics from a few months ago?
BW
I didnt see it there but do you have a intake air temperature sensor( the sensor that goes in the intake filter)?
Inneedofabuick, what info do you need?
MIKES86GN, will get some pics of intake on monday, you're second in line, for both items.
Bryan, guess what? got a dig. cam for x-mas :biggrin: pics coming.
bishir, sounds hawaiian, doesn't it? actually, i'm right near montreal, quebec canada.
GNguy, sorry, i only have the ones on my car.
25 shipped for the clear lights and one exhaust elbow? i have paypal too.
Thanks,
Greg
WHAT WILL IT COST TO SHIP THE STOCK INTERCOOLER AND THE STOCK I/C SHROUD + SCOOP TO PA. WHAT CONDITION ARE BOTH IN? CAN YOU SEND PICTURES OF BOTH TO ME....
THANKS VINCE
-stock i/c shroud+scoop- $30
turbogreg, lenses are pending, will let you know.
Cheeseburger, will get pics on monday, parts are still on car.
Im sure there arent too many guys looking for a sage green steering wheel, but if its the correct one with horn button i will take it.
Email pics to me at wanner@kc.rr.com
Bout time you got a camera!
BW
