Just got the motor together now for about a month. Everytime I start the car it takes awhile to build up oil pressure but when it does come up it's good.
Also the oil pressure seems to be pretty high. I got the lightest relief valve spring in it and when it's warm oil pressure is about 45-50 psi and when I get on it, it maxes out at ~70 psi.
More than most & just wears out cam sensor gears faster. Important thing is it rises 10lbs for every 1000 rpm. What weight oil? Maybe go with some thinner oil?
Might check your oil filter. Some of them do not have an anti drain back feature. I do not remember which one has it and which one does not but I am sure someone will chime in to give the filter numbers to use. Also did you adjust the roller lifters correctly. If you have too much pre load it will drain the lifter.
Jeff
