Sorry about that, I forgot you have to be registered... here the part I disagreed with..
"I also want to point out that although methanol does indeed have a higher octane rating than typical gasolines, its heating value is quite a bit lower making a poor substitute as a fuel. In other words, since you reduce the amount of gas injected to keep the AFR the same, there will be a net drop in indicated power"
My response:
"Most people running alky injection setups aren't running the standard AFR in fact they are running closer to 10:1 ratios to compensate for the lower specific energy of the alcohols. It's more inefficient in the amount of fuel used, but it's cheaper than race gas."
What do ya think?
