SignUp Now!What about any other hoses or wires that need to be disconnected?The one thing that procedure forgot to mention; Remove the bolts holding the power steering reservoir to it's bracket. I forgot to do that when I raised the driver's side of mine and the reservoir comes up with the body, while the hoses are attached to the pump that doesn't rise with the body. The hoses ripped the bottom of the reservoir out. What a mess.
You'll Have to remove the bumper fillers or bumpers. The fillers will hit bumper. I just swapped my bushings the other day and it was a piece of cake. Super straight forward.
Haha yes they were extremely corroded. The two passenger side nuts in the trunk were seized so I had to cut an access hole in trunk pan to remove and weld in new washer/nuts. The passenger #3 was seized so I had to cut a hole from above and drill out and install but bolt there also. Besides that no surprises. Get some grade 8 bolts from kirban for the $40.00.
good luck!!
