Determining Pressure regulator boost valve size
PaulRV6
How do I know what size boost valve is installed in the pressure regulator valve system? Is it just a matter of measuring the boost valve OD (item 222)? I removed a valve that measured .531" OD and installed the CK valve. Not sure what size it is until I measure it but need to know if that is the way to tell?
Is the bigger the valve the better?
paul
