Detonation issues, I think.?
For one I think your trying to change to much at once,and turn the alky down a little,or the turn on point up.
As far as the trans goes try reseting the TV cable(its the one everyone calls the kickdown cable)
Make sure the floor mat is pulled up,push the detent on the side of the cable housing in(it's tight)then pull the cable towards the Firewall,
Next sit in drivers seat and press the throttle pedal all the way down,and you will hear a clicking sound.
The TV should now be set,you can also customize your shifts a little by moving the cable housing a little each way.
BUT what this all boils down to is all of this is useless with out a scan tool to know what is actually happening.
I got a scan tool and all the numbers are good!
I did find that the 20 yr old cat I used to pass emissions was broken into little pieces! Once the cat came out "for testing purposes"- I added a THDP and a test pipe and the car came alive!
I have yet to tune the alky for it but WOW! what a difference.
