C
Chad Maskrey
Guest
I have installed this on a 2000 mustang gt. The car starts fine but will not rev past 2,000 RPM. It is not advancing the timing. I have changed the ecm,ign. module,and checked OHMS on all wires to IGN module and they all check out. I was told this is a safe mode. The timing on the car is reading 10 at teh balancer,but the DFI reads 20 degrees. I need to know what to check for. I am looking for any advice.Besides the ignition problem the car idles fine,doesn't overheat,. I hope it easily solved. Thanks turbobuick.com JEDCASTER@NEW.RR.COM
