hot air 84GN
 - May 7, 2009
Everything has been running fine, without problems.  Noticed early in the spring, that sometimes when starting the car I have a problem.  While cranking the starter, it stops and hesitates.  Then continues to start.  Almost like a weak battery.  I charged the battery and now run a battery maintainer.  So I don't think that is the problem.  Scanmaster reads 12- 14v.  So I briefly thought it may the starter.  I have had it out before checked the terminals and re tightened. Which I am going to check again.   A car friend mentioned it sounds like the timing is off or advanced.  I immediately suspected the original cam sensor or cap, since I have replaced the coil, module, wiring leading to ignition, and crank sensor recently in the last few years.  Could a faulty cam sensor or cap cause trouble when cranking?
I'm not positive of anything, because it runs fine after it finally starts. Any thoughts would be greatly appreciated!
