OK, we have everything plugged in and working. DFI VI 6.32 software.
Calmap links with the ecu, and can read the ecu file, and edit it.
Tried starting the car, and it started and ran.
Very rich, ie pegged the WB.
Went to base fuel map and dropped the entries down to 10, and it's still rich.
Went to View, and the PW is 3.1 and in the table the entry shows it should be like .8..
Brought things back in the house, and reran the inputs to the ecm on the bench, and it's seeing MAT, CAT, RPM, MAP, all correctly.
In V the highlighted area matches the inputs.
BUT, the PW still reads a fixed 3.1. If I turn off the ignition/RPM signal it drops to 1.0...
The configuration seems to be correct, and the ecm had been on a known good running GN.
Pointers appreciated........
