Here's some pics of the ECM panel I built installed in the car. all the underhood wiring is in place. I like wiring stuff but now I have to do the interior and behind the dash and the car has a cage. It's a PIA climbing in and out of the thing.
Originally posted by turbochris Here's some pics of the ECM panel I built installed in the car. all the underhood wiring is in place. I like wiring stuff but now I have to do the interior and behind the dash and the car has a cage. It's a PIA climbing in and out of the thing.
Just as something to consider in the future, you might try pointing all the connectors so that the wiring points down. ie so that the ecm is wire connector end, down. That way in the event of blown radiator hose, or some conductive liguid leak, gravity will be working with you to try and keep the connections dry. Min., often not easy to do, but beats dieing on the track.
