Did some upgrades and GN now popin n sputtering @ WOT.. HELP !!!
Soldier_GN
Heres the situation...
Couple of weeks ago i upgrade a few items from stock...I put a 60-1 turbo, 32-3400 SC, PLX WBO2, LS1 MAF & Translator, Razors Alky w/ 3 bar MAP, TT 5.7 Alky chip setup for 23*-21* and 23-25 lbs max boost and GN Knock guage...
Now car was running great before all the upgrades. As soon as i take it on its maiden voyage the car is popping and sputtering @ WOT. RUnning 91 pump gas with Meth on #5. Now i cant get her to run right. took some SM & PL readings/ numbers....Attached are 3 Pl files...one taken at idel and the other two on WOT runs....Let me know what u guys think.... Please need help ASAP....:mad::(
Dont know how to attach the damn PL files.....FML !!!!!!!!!!!!!!!!!!!
Johnathan
Engine off ign on
O2 442 0.0
AF 4
L8 0
BAT 11.6
INT 128
BLM 128
CLE 77
ATS 83
RPM 0
TPS .40
IAC 140
CC 0
PU 9.1
SP 0.0
MAL 0
Idel warm
O2 827-831 0.0
AF 5
L8 34-36
BAT 13.9
INT 128
BLM 118
CLE 167
ATS .98
RPM 800
TPS .42
IAC 13
CC 149
PU 2.3
SP 26.8
MAL -
After Run 1
O2 831 0.0
AF 5
L8 33
BAT 13.7
INT 128
BLM 118
CLE 167
ATS 112
RPM 800
TPS .42
IAC 10
CC 21
PU 2.2
SP 27.1
MAL -
After run 2
O2 811
AF 4
L8 32
BAT 13.6
INT 128
BLM 118
CLE 17
ATS 114
RPM 800
TPS .42
IAC 11
CC 95
PU 2.2
SP 26.8
MAL -
Update...
So i got a note to lower the timing to 15* & 18*...same thing....dosent seem as bad though....any thoughts TB ????
In some cases the maf can pick up interference from the alky pump. If that is the case you would see it on pl log. The maf signal on the graph would get real choppy and erratic. In this case the power for the translator or alky system needs to be moved. I ran a hot wire off the alt to a relay under the dash that runs alky and a couple other accessories.
Did you try a zip the log then attatch? If you still can't attatch, send it to my email. turboburick@sbcglobal(dot)net
RL
TurboBuRick
thanks for the info...will check the.wiring...my mechanic did the.setup for me. i will try and zip the pl files and send em to ya...thanks for your help...its much appreciated
Johnathan
Had a quick look and going by your WB02 (i assume you have it hooked to powerlogger) You are running pig rich
Yes PLX WBO2 connected to PL...pig rich...really ??? How far down would i recommend i take it ??? Im at the base right now... I got 42.5 LBS injectors... It should be at 42-43 LBS stattic with vaccume off right ??? and then dial it down...but how much...what kinda #'s should i be looking for on thw WBO2 ???
File 000: I see you now have a boost signal so you can ignore my last PM. TPS only 3v !!?? WB reading 10.00's !! ?? WAY rich!!
File 002: same. TPS WAY LOW!!!!!!!!!!!!!!!!!!!!!! WB reading WAY RICH (wb appears to be working normally) at 10.00's !!!!!!!!!!!!!
It's too rich for that low boost, since the chip was made for 23-25psi, and you're only running ~17psi. If you keep the boost that low, then you'll have to back the alky and fuel down until it cleans up.
You won't need much alky for that kind of boost (17psi), so you might try turning it down a couple numbers. If that's not enough, then reduce WOT fuel using the chip adjustment.
The other option is start turning the boost up. Be careful and watch for knock.
Regards,
Eric
Plan of action...
Start 14 # of boost and work my way up to 23-25#'s. Gona fix the TPS @ WOT, set it to 4.5. And see what happens....Thanks again to everyone for all your input, without you guys id still be stuck holding my you know what....Well see what happens in the next few days....Thanks again TB...
