Dies, Help!
Pace 1989
My car dies when slowing down. Usually idles fine, it's almost like the trans stays in 2nd gear and just pulls the engine down. When slowing the rpms just keep going down.
Also if I'm driving at a steady speed and quickly let off the gas the rpms drop down to around 500 and then jump back to normal. I've reset the computer, the minimum air rate, the IAC, checked for leaks in the intake, looked everywhere. Any ideas? The only thing I can think of is maybe there is a leak in the crossover pipe. Would it cause this?
Ken
Maybe a bad TCC solenoid? Maybe try unplugging the 4 wire connection on the driver side of the trans and see if the problem goes away. If so you've found the problem.
