- May 28, 2001
Am locating the turbo on the LS, and am using a junk, [leaks oil], Chinese made T-76 w/ .81 A/R turbine hsg, T4 flange, as a mock up. [4" inlet/ 2 1/2" out, 3" split flange exh.]
I want to be sure when the hot side is all welded up, I have enough room for a larger turbo.
I want to step up to a .96, [or larger 1.10], as the eng will need it. 5.3 for sure. Maybe a 6.0.
Will the larger A/R hsg be a/any significant increase in OD?
NE suggestions as to a particular turbo?? Keep in mind this is not a race car, just your average streeter...
[Using junkyard engines w/ some minor upgrades.]
TIA,
TIA,
