I am in the midst of having my trans rebuilt after a forward drum failure. This trans was last built in 1995 by Mike Kurtz and I got +- 200,000 miles out of the trans before the forward drum failure. In then end I want the trans to shift just like it did prior to the failure. Obviously this is a daily driver. At the time borg warner clutches were used. Mike had setup the direct drum with the thinner forward drum steels and an additional direct drum clutch, machining down the clutch plate. Some say not do this, Alto offers a "power pack" kit that essentially does the same thing.
Right now I'm inclined to keep it the way Mike had it since every tear down I had done (the lockup clutch in converters don't last 200,000 miles) the soft parts were perfect so we simply put new seals in it and that was it. Even now I could reuse the borg warner clutches but obviously make sense to do the soft parts. I'll use the Alto clutches and band.
Any suggestions/coments?
1. Do I use the Alto Power pack kit and new backing plate
2. Revert to stock .090 size steel's (need new direct drum or stock backing plate)
3. Use the forward drum steels like Mike originally did and an extra direct drum clutch?
Thanks!
PS. This is for a 12/13 sec daily driver TR that sees about 20 runs a year. I don't drive it quite so much anymore (20,000 miles per year) since I"ve already put 330,000 miles on it.
Thanks!
-Gerry Bragg
Brighton, MI
bragggf@sbcglobal.net
Thanks!
Thanks!
-Gerry Bragg
Brighton, MI
