direct scan install help
85turboT
I need some help describing exactly how to install direct scan on the ecm in the car I had my ecm out and removed the cover and I cannot find where the ds ribbon plugs into. If anyone has photos or can describe it I would appreciate it greatly. Thanks everyone
its same as for powerlogger
you need to open the case at the chip end
remove two screws on side ,
i like to run a file over edge of case first to weaken it
fold up the end and break it off
clean the goo off the edge of circuit board
the instructs should be here, pg 6 shows what im talking about
http://www.chuengineering.com/manual.pdf
and heres the software
http://www.chuengineering.com/dsv1_52.zip
youll need an older pc (win 95/win 98 or earlier, heres the system requirements
http://www.chuengineering.com/sr_main.htm
