distributor and msd7al on stock ecm
norbs
Classic fast, XFI, SPortsman & MS3 programming
I am a few days away from the install of the msd billet distributor on the stock ecu. I bought a hall effect sensor from motorsport innovations and installed it into the cap window. I will give a status report if it worked or not, or if the msd7 creates too much interference.
We'll be waiting for the flash in the sky from over the border when you get through Norbs. LOL
1st attempt has Failed the hall effect sensor is not working using the reluctor as a pickup. PLan B is to make a magnet pickup in the distributor somehow
The mad scientist is hard at work.......... I have got a MSD7AL-2 and MSD Pro Power coil forsale if you ice yours Norbs. Good luck, and keep a fire extinguisher near by just incase;) I will give you a shout later to see how you are making out.
Thanks, knowing my luck i need lots of spare parts........
