DIY solid anti-roll bar article
Looks good, I think you would have better success if you welded the mounting tabs on the axle tube straight up as opposed to on the side of the axle tube like the Wolfe bar is supposed to be. I guess they did that for more reliability issues. It would be harder to snap them off if the load is being put on top of the axle tube as opposed to the way you welded the tabs on the side where they could possibly sheer off the axle tube. Just a thought but that looks very good.
That is an great idea. The only thing i would add is a center support.Let us know how it works.
