this is my first trans build
when I put car in 1 2 or 3 it wants to go foward, reverse is like neutral..... not a detent issue as same problem is with shifting by hand into reverse
trans is a follows alto power pack kit every bushing is new every thrust washer and bearing is new all new pump gears new ptc convertor 34 element roller clutch all new borg warner bands I followed tips from the th400 thread as far as th350 pump bearing in rear of case restricted pump feed to save crank thrust bearing
also the 1 bolt hole on the valve body spacer plate does have the bolt in it
what else to look for ?
