DLS Roller Cam set up, T&D Roller Rockers
Limited87
I have a used DLS 210/212 ast roller cam set up for a turbo V6. Included in this package will be the Comp cam shaft, beehive springs, retainers, locators, 5/16 push rods 8.475 in length, also the T&D 1.55 roller rockers for the Champion GN1 alum heads. These can be made to work on cast iron heads but you must have the spacers modified to do so.
This set up is out of my 9.75@139 TSM style motor. This cam is very mild and an excellant street or track cam. Idled and drove perfectly with a chip/ecm/maf set up with a Reds chip. The set up has around 500 miles and 30 passes. I went to a bigger cam and larger set up for this year is the only reason for sale. Cam will come with the DLS cam card also. I do not want to seperate these parts at this time.
Priced to move at $850 FREE SHIPPING IN THE CONT USA!
Paypal accepted plus fees.
Thanks,
Brian
that is a deal and a half with rockers :eek:
Is it a custom grind? I thought Dan didn't do split duration?
I agree its is a hell of a deal for somebody. To duplicate whats here is $1300.00
+1 Dans would be a 212 roller not 210/212?
Technically its a 210/212 but he calls it a 212/212. Here is the cam card for it from DLS. Call it whatever you want I guess either way the car made 700 horse to the wheels.:D
Would those rockers work on TA heads? The SE's not the SI's that take the offset rocker.
Coach
