Do i find the wierd stuff or what!!!
geno
9sec 17MPG Street Car
Staff member
Ive never seen a 25500153 block that didnt have cross bolted front and rear mains before;) I bought this block as a dooner for a friend that needs a piece of pan rail..
http://www.netSnapShot.com/users/2412/images/PJBto8CoBQIAAEyPyMw_2412_275.jpg
I bought this one because its a 4.010 bore and its has been repaired but they did a nice job:) The cylinder bases are not hurt and the regiesters are tight..I just cant say no to good S2 deals. I tell ya i need help;) Im getting one more block,crank and heads from this guy and i swear im done digging up these S2 parts..
http://www.netSnapShot.com/users/2412/images/PJBup8CoBQIAAEyEa00_2412_276.jpg
Got 2 on-center ones without cross drilled mains. It is basically just like the late release off-center blocks. I like them because I can use the internal pickup, and not have to put the Dutweiler pump on. Still got one of those brand new in the box.
s2 motors
Hell, I don't know what you want Stage Motors for. You went 990's on a stock block.
YOU SPEED FREAK!!!!
GIVE EM HELL GENO!!!!
Unless the machined surfaces are too far gone on the first bock,I would sleeve it and make a piece out of steel to braze in for the second block.Now you've got two good blocks.:) You can thank me later,big guy.
If I had to guess what the heads were, I would say experimental aluminum production heads.
No 14 bolt configuration, and never planned to.
Nothing that is a big deal, just a piece of history.
Cool stuff though.
I'd like a set of the 14 bolt stage I heads.
