I've been researching 200-4R options and am trying to determine if I "really" need the billet input shaft/front drum setups or not. I've talked with a couple of shops and read some of the available information from several more and havn't convinced myself I've got a consistent picture.
The car should weigh under 2800 lbs (I think 2500 is possible). Rear is 4.86:1 with 15.50 x 29.5" tall tires. Power estime is 550 HP and 560 torque (it was dyno'd at 600HP but I'm going to take out some compression and cam to make it more streetable). The car is basically going to be used as a "street rod", which will likely get raced once or twice a year. I'm not really sure that I'll get a set of slicks to race it, may just run on the street tires (Hoosiers) since it's just for fun.
So, do I need to step up to the more expensive trans options with the billet front shaft/drum pieces??
Thanks - Greg
Thanks - Greg
