I finally got some used braces that tie the frame horns to the front cross member.
It looks like on the cross member the braces attach to the welded block that sits just forward of the cross member?
If so, I am going to guess the holes that are already there must be tapped?
Because it doesn't look like you can insert a typical bolt in there for the brace to attach to.
Or am I looking at the wrong holes?
Thanks in advance.
Thanks in advance.
