Do I remove my EGR valve, what are the pros and cons?
evil666
I would want to know if I should remove my egr valve and close it off with an after market block off egr plate? What are the pros and cons, for example is going to affect the idle of the car? Does it matter if I remove the egr valve even thow I drillled a hole in my rjc power plate to use with the egr valve? Does it affect peformance in any way, etc?
Thanks for any help.
Marco
86 Grand National t-top (59900km)
stock long block,stock suspension, red stripe convertor, te44, smc alk injection, 24lbs boost, 94 octane, hooker cat back with dyno max ultra flow muffers, tomco 30lbs injectors, dynotech stage 4 street chip, thdp, mease 24 row IC, Ron Custom max boost brake module, MT drag radials (275/50/15) 3800lbs race weight with driver.
BEST E/T
60FT=1.52
1/8= 7.38
I/4= 11.74
MPH=113
BESTmph=114
