Turbo__Tim
One heck of a Tim!
- May 25, 2001
A quick E-Mail to www.importpoweronline and the response I got back was that they were not needed as their kits work fine down to 80 PSI.
Is it true that the output of the system depends on the regulator, and not the regulator? I guess so that's prolly why they call it a regulator...![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
When I tried this system out last summer it ewas in 95* heat and it worked fine. Now I see people that want bottle warmers. Is this because nitrous bottles need this? Maybe we don't.
I can't wait 'till I an take my G/N back out this year. I had just gotten the 2 stage alchy hooked up, and tried the propane system one day and the computer freaked on me and sent the timing to 28* and wouldn't budge. I backed off the translator timing to make up for it (sorta worked) and went out to test the propane some more and..BAM! a little old lady ran a light, taking out the entire pasengers side.
By the time the car was back from the shop, and the timing issue resolved, winter was upon us here in New Jersey.
Anyway I had the IPO kit up to 23# psi, and it worked fine. Apparently Chris now has a low pressure warning light for $75 that can tell you when the pressure in the bottle is lower than the limits that you set.
I am going to E-Mail this thread to IPO. Perhaps he can prove to us, once and for all that the warmer isn't needed. I'm sure that he could provide links to his board that show this.
At this time I don't see the need for one. Maybe our cars with the larger displacement engine need something extra.
We shall see in a month or so, when the G/N is on the road.
I'll be integrating the 2 stage alchy system as well. From what I see here, and particularly on other boards, the 2 can work in tandem. Just use less alchy, maybe?![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Hey IPO, show us the thread and picture where you made an adapter to use the small propane bottles. How many runs can you get out of a couple of these?![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
