SignUp Now!Patrick,
I purchased a low mile PT-51 from a member on this board, he had a 11.08 pass on this turbo w/ 25psi of Boost. Judging on the above compressor map it looks like this turbo hits it's sweet spot at 26+ psi. What would be a safe level to run this turbo with my below setup unopened long block, running 93 oct w/alky and not risk turbine implosion. I don't know anyone that has run one of these besides Red from EVTB, and his opinion is probably not impartial as your's would be.
thanks,
Ben
As said before, that map is not dead on for the PT51, it is merely the closest map ever published by Garrett.
Here's the kicker.... 50# injectors.
With alky and 50's you will be running low on gas if you run over 30psi on that turbo. Also, you will need a chip that has the capability to run 100% duty cycle on those 50's #ers, just to be safe. Maxed out, 50#ers will safely support 600 flywheel hp. You will be getting close to that level if you maxed out the turbo. That turbo with 50's and alky is a nice streetable combo for sure. I would be concerned with the condition of the internals and the turbine wheel on that used PT51, eventhough it's a low mileage unit, before just going willy nilly with the boost knob. But you should be fine running it at 26-27psi.
What we really need to know is, what is the T350 turbine wheels' death point? This can be determined with a turbine wheel map, but those are non existant and are not published by Garrett. The Stage 5 turbine wheel from Turbonetics is close, but not exactly the same. And even if the true Garrett map was availalbe, it wouldn't be applicable with our Buicks' 3-bolt style turbine housing. From what I can remember, we did not recommend running that turbo much past 30psi, as you are running very close to the edge of both wheels stay in one piece. IE: Not exploding due to overspeed condition. The easy way to figure out a turbos limits, and this is true for any turbo, would be to run a back pressure gauge. Some people have made homemade back pressure gauges by plumbing a copper tube line just below the inlet of the turbine housing, into the header, coil it around a bunch to help cool the line and the signal, and run a pressure gauge that can read up to 100psi.
The general rule of thumb is, once you reach the 2:1 back pressure to boost level, your turbo is done. Example, your boost gauge reads 30psi of boost at the intake and your back pressure gauge shows 60psi, you're done. But, if it shows less than 60psi on the back pressure gauge, either keep pushing it till you blow the heads off the motor, or over speed the turbine wheel and or compressor wheel. This can be a very fine line to figure out, not too mention a costly one. Just ask all the serious Import guys who are twisting hard on GT42 & GT45 turbos. It's nothing for those guys to run 40+ psi, but we'd blow the heads off our motors at those boost levels. The other issue with running very high boost levels is charge temps going out of control. This can be somewhat combated with Alky and an efficient front mount, but it's not good to really run any rotating assembly at the ragged edge over and over again. I mean, we're talking about 140-170K RPM levels here for the rotating assembly. Things can happen really fast if something comes appart.
Sorry to ramble on, hope some of this helps a little.
Patrick
