My parts list
Feed line-
Summit- 8AN hose ends x4 220890 $6.97 each
20ft 8AN Hose 230820 $84.97
Inline 8AN fuel filter 650100 $23.97
Racetronix- 8AN to 16x1.5 machined adapter 392-460816BLM $7.76
Return-
Summit- 6AN hose ends x2 220690 $4.97 each
20ft 6AN hose 230620 $74.97
Racetronix- 6AN to 14x1.5 machined adapter 392-460614BLM $8.46
I'm using the racetronix AN fuel sender in the tank though, so if you dont use that youll need to measure the lines coming off the sender and get the fittings that go from hard line to the AN line. Also, you can save money on hose if you get the PTFE style, but then you have to buy more expensive fittings. I also believe you can save about $4 a piece on the fittings from racetronix if you dont get the machined out ones. I believe this is about the simplest and most cost effective way of running the fuel lines
