Does ECU-GN use flex fuel sensor via factory MAF plug like SD2 does or will I need to rewire?
tminer
Not quite normal
Preparing some changes while waiting on my ECU-GN and curious about this. I assumed it would but lists MAF input as an optional frequency input from what I've read. Maybe for flexibility. Easy rewire, just want to make sure.
Yes, the MAF input is used for the Flex sensor.
Bob
Ping me or call if you need any help to set it up, but the defaults are correct for most people, you just need to enable the flex function.
Bob
