i was surfing around ebay and came up on the "electric supercharger" the fan in a tube. i read it and got a good laugh. then i started thinking. why do peopel use electric water pumps? electric fans? the answer is simple, it doesn't suck up as much power, your already spinning an altinator, why not use it.
there is no reason an electric motor can't spin as fast or with as much torque as a normal cyntrifical blower spins, whats that probably 10,000 rpm's? an electric motor can do that pretty easly and still make plenty of torque to move some air. so wouldnt' it not only be possible, but beneficial to make an electric driven blower? i know the little fan in a tube won't work, but i'm thinking like a compressor housing off a turbo, or maybe a roots based design, something that would be capable of making positive boost. to me it sounds like a great idea. it wouldnt' be a little "put this on any car" thing it would be more application specific as it would be big, probably using a motor similar in size to a starter motor and a big trubine or whatever kind of blower housing. it would be able to come on at any point, 0 lag, and wouldn't lower the boost with lowr prm's like a blower does when shifting. the boost level would be 100% tunable, and i'm sure it would be able to be connected to a knock sensor to reduce boost when knock is seen. when you don't want it just turn it off. have a one way bearing in it so its non restrictive. basically is the same idea as those silly e-bay items only suped up and actually worth something. the only down sides i could see would be the need for a pretty solid electrical system, probably no more than what would be required to run a mild stereo though.
i of corse dont' have the money to actually make something like this, much less produce it, i'm just thinking out loud.
