Door panel pull strap trim pieces
CliffyC
Need a couple of the plastic trim pieces off the door panel that the pull strap goes into. Mine are all busted to h....! Thanks
Actually need the escutcheons (just found out what they're called) and Highway Stars sells them for $86 a pair. Used ones would be fine if anyone has some.
Are you talking about the strap caps that kirban call them?
Only the piece that covers the screw is called a escutcheon, you need that and the whole trim piece from the looks of your pic. The escutcheons you can buy new I'm not sure about the rest of it?.
