Door rebuild... whats this?
GN noob
Hey, I am in process of rebuilding the inners of my GN door. New regulator rollers, window motor, lock cylinder, wiring, etc... and there is an extra connector that doesnt have a home. All the electrical bits are accounted for and this connector was just floating inside the door. Anyone know what this is supposed to go to?
Also, I am missing the front upper stop bracket, if anyone has an extra, I am interested.
Thanks!
The lock solenoid is connected. Its those white and tan wire in the background.
Did these cars have side mirror defrost? maybe courtesy light?
No mirror defrost option. Courtesy light is the switch on the inner door jamb(by the hinges).
Do the power locks work?
That make more sense. The door panels have been replaced in this GN.
Does anyone have a picture of the lower panel light? I havent been able to find a picture (at least for an 84 GN) of what its supposed to look like.
Well it doesn't match up with the connection so not it.
stock speakers in the door? I had no idea! I checked RPO codes and UW4 is there.
I took a look in the passenger door and found a set of green wires that are cut. I will trace these back and see if they go to the stereo.
Is this system worth putting back together? sounds like a cool feature.
