Downpipe, ecm proms, test pipe, turbo , elbow, tb, plenum ,
gn4u2c
Yes Its fast no you can't
I have a hypertec for blue tops 93 oct, Only use it with 93/ alky as it has alot of timing worked perfect with alky ! or use it as a core to redo. $20.00
Red Armstrong 107 race chip for 009's $20.00
ATR Pitbull streetchip for 009's $25.00 (aggresive chip your car must be in tune lots for low/no boost power for street driving)
2.5 hooker test pipe $15.00
Stock downpipe, $40.00
Stock elbow $25.00
adjustable wastegate for stock/ta turbo $40.00
Stock upper plemun $40.00
Stock TB good shape $40.00
Stock turbo little play look like some oil is getting past or maybe just a because it had the tube to the valve cover hooked up , either way $75.00 and its yours. complete with inlet bell.
Or take everything $300.00 shipped
Stock elbow $25.00
pic of 2.5 hooker test pipe?
it is attached to the downpipe in this pic however it is not welded and will slip right off
