Jan 25, 2010 #1 L Lorenzo Member Joined Nov 7, 2006 Messages 118 I have a set of 16" GTA wheel and I would like some one to tell me what is the biggest 16" drag radial that will fit with out cutting the car.
Jan 25, 2010 #2 toofastforyou 2FAST4U Joined May 25, 2001 Messages 5,785 Lorenzo said: I have a set of 16" GTA wheel and I would like some one to tell me what is the biggest 16" drag radial that will fit with out cutting the car. Click to expand... M&H makes a nice 275-55-16 size drag radial tire...(see picture below) Claude. :wink: P.S: note that in the picture, the rim is 10" wide, but these tires will fit on an 8" wide rim. Hope this helps...
Jan 25, 2010 #3 B Brer Rabbit Pursuit Specialist Joined Feb 5, 2005 Messages 2,892 I run a 255/50/16 Mickey Thompson. It fits very nice and is 26.2" tall. I think that M&H is 28" tall which is why I went with the Mickey as its the same size as the fronts.
Jan 26, 2010 #4 G grocerygetter Active Member Joined Mar 8, 2005 Messages 1,203 you can run a 28" tire if you want the gearing change....don't forget a 27" tire does well also. I don't think I want to go back to a 26" after driving on 28s.
Jan 26, 2010 #5 R RussellinNC Car lover!!!!!!!!!!! Joined Jul 29, 2001 Messages 201 toofastforyou said: M&H makes a nice 275-55-16 size drag radial tire...(see picture below) Claude. :wink: P.S: note that in the picture, the rim is 10" wide, but these tires will fit on an 8" wide rim. Hope this helps... Click to expand... Looks good!!! Russ
