Can I just mark the locations with my heads installed on the block and then drill the holes out myself at home?
Is there some trick to this that makes it impossible to do at home?
I'll have the car apart over the winter and want to add the head studs to the car. The heads are ready to accept them and I have a complete set of studs.
  I woudnt try a mag base drill because it will drift
 I woudnt try a mag base drill because it will drift If your holes are not perfectly perpendictular to the deck and you use studs the heads wont go over the studs if you install them before you slide the head on
