Jan Larsson
- Nov 22, 2001
At stand still with engine running and switching between drive and reverse I have a "clonking" sound from the drive train. I need to go under there and see what it can be, sounds like metal moving and hitting something.
I have new U-joints (heavy duty version) that I installed about a year ago or so. Also a new poly torgue arm bushing installed about a year ago also.
Is there anything that can be loose? I will check all the bolts for the torgue arm and rear axle U-joint. Anything else I should look for??
The sounds is very loud and have not been this bad previously.
