I'm right in the middle of changing my timing chain so while I have everything apart I decided to remove my driver's side header to look for any cracks. When I finally had it removed I could not find any cracks (between 3 & 5 either) . Should I remove the heat shield on the header to see if there are any cracks on that side? Is that the side where everyone finds the cracks?
The only reason I decided to remove the header is because I could hear the distinct exhaust noise coming from that header when cold. Thanks for your reply. Nicholas.
'87 GN w/ 20k miles.....
