Turbo6Smackdown
- Dec 31, 2005
If you're running a factory pcv setup, and have a breather on the passenger side valve cover, do you have to run a driver's side breather as well? Is it absolutely essential?
So with my set-up, and 18 or so psi of boost with alky would I be good with just the passenger side breather? I have a breather on both valve covers, but was wondering if the driver's side breather was totally necessary. I run a factory pcv valve. Though, I do see oil in my vac block when I take it off of my throttle body. So is that pcv valve failing? Or are my breathers in adequate?
I've heard of guys running up to 30psi having problems. I've been at ~24psi for a while with no ill effects so far.What do you call high boost?
cork gasket from kirbanMy car leaks from the oil pan, that's about it. WIsh someone would come out with a GOOD oil pan gasket for these cars
i have ran 30+ lbs of boost with both breathers and no oil mess so farI've heard of guys running up to 30psi having problems. I've been at ~24psi for a while with no ill effects so far.
